96 Explorer New Member | Ford Explorer Forums
How old is the battery? Have the alternator tested? What’s the voltage across the terminals at idle, and when off for a few hours?
Bad battery?
Good battery. Volts were at 14. Tomorrow going to check the hidden fuses.
Hopefully it will be that.
If it shows 14 volts at idle it won’t be any “hidden” fuses.
What is the voltage of the battery disconnected from the vehicle? Also, if possible check the specific gravity of the battery electrolyte, this will tell you the condition of the battery. Additionally, you can have a battery with 12v, but not be able to handle the amperage load the starter needs to spin the engine over.
