you should use something stronger than wd40. get a good penetrating oil like good ol PB Blaster. u will be amazed how well it works. wd40 is nice for small squeaky things but when u need to break bolts loose i would definitely get some pb blaster and let it soak a few hours.
and is there a way to tell how much lift your gonna get by using an add-a-leak kit before you put them on, i found some from summit and i cant specify what size to buy?
