96 ford explorer wheel bearings | Ford Explorer Forums
GreenBayGuru
Milwaukee
96 Explorer XLT
I'm just wondering what it all entails to replace both my front tire wheel bearings and if its a job I can do in the driveway or should I take it in?
Like what kind of tools would I need?
This is my 1st attempt ever at wheel bearings =/
Use the search function on the site.
You will find a very informative how-to, with plenty of pictures.
______________________________________________________________________________
Its actually a "sticky" on the very first page of this section as well.
http://www.explorerforum.com/forums/showthread.php?t=165429
You just need to take the axle nut off, the brake stuff, and break the 3 bolts holding the hub on loose. Those nuts are a pain in the ass if they have never been off. First time took me about 3 hours not knowing what i was doing.
Here's a thread on how to change your front hubs.
Just remember to spray plenty of liquid wrench on the bolts before you try to remove them and tap them with a hammer to loosen up the rust.
This is definitely some thing that you can do. The above link will tell you what you need to do the job. Good luck. :)
quick and painless job is to try and take the knuckle off makes this task very easy! trust me.
