96 ford explorer xlt engine vibration help please | Ford Explorer Forums
omygrinder
Orlando Florida
1996 Ford Explorer XLT
i just bought a 96 ford explorer xlt 6 cylinder and when i step on the gas when parked theres engine vibration thats not normal but when i drive it passed 25 miles an hour the vibration tend to go away. does anyone know what i need to do in order to fix the problem.
How does it idle? does the engine shake while it is idling? How does the air filter look?
How can you tell it is the engine that is vibrating?
***never mind...just saw this happens in park while not moving***
Can you describe the vibration better?
idle
the suv when idle theres no engine vibration
vibration
when i hit the gas when parked i feel engine vibration sitting and it makes like a vibrating sound
engine vibrating
when i drive the motor vibrates too but not as much like when its parked and i step on the gas.
Hmmmmm..... kind of sounds like it is misfiring, how is the condition of the spark plugs and leads?
spark plugs are new and the wire set is not new, im going to purchase new spark plug wires to see if thats the vibration problem.
intake filter
intake air filter is new
Engine Vibration at 1500 RPM
Guys, on a simuilar topic (engine vibration) I need some help please: I'm talking about a 1996 Eddie Bauer Explorer, V6. Roughly at 1500 RPM the engine vibrates, especially when I demand more power, going uphill for instance at moderate / high speed. What can be the reason?
Thanks!!
Did you replace the wires yourself? Did you get the firing order correct? OHV or SOHC firing order...Ive done that before lol
