BenMar
- July 25, 2010
- Iowa City , Iowa
- '96 XLT
Hi - New here , and I've been searching the o2 sensor tips , but not found the "right" one yet . I'm building a daily driver from a wrecked 96 Explorer , with the 4.0L V-6 engine. My body is a 1953 Studebaker pickup with the same 112" wheelbase. Since I will be using the '53 Stude title and license , I can modify the exhaust system to accomplish my goals. I want to split the exhaust system to be able to have the old fashioned dual exhaust. Now on to my question : if I keep the two front oxygen sensors in place , but cut & split the "Y" pipe before the cat. converters , what negative things will happen if I pitch those two converters and the last two oxygen sensors? I'd like that neat sound from a split exhaust V-6 engine , and I want to use the turbo style mufflers on each side . My unanswered questions are in regard to keeping the PCM happy without having the last two sensors doing anything anymore ! If I simply unplug the last two sensors , and tape off the wires , going to work? Will I cause the Check Engine light to always be ON ? Thanks for any suggestions . Ben
