trevvor
- August 17, 2004
- Phoenix AZ
- 97 XLT
Is this a problem, or is it not?
At 59k miles I had my 97, 5R55E tranny fluid changed as per 60k recommendations. Had an independent shop drop the pan and replace the filter, I don't think they flushed it cause they only charged my $11.25 for the ATF.
At about 60K the tranny begins to slip in 1st when cold. My mechanic recommends a transmission shop. The transmission shop, after tear down, recommends a rebuild (of course). I get it back and now there is a new problem.
When in OD, TCC seems to slip when a slight load is experienced. I'm going down the road, 50 mph +, always speeding up and slowing down with traffic, but when I speed up, it feels like tranny slips. Tach will rise by 100 or so and then drop back. When I'm on the freeway, cruise control on, go up a slight hill, same thing happens; rpm comes up and then drops down. It does this constantly whenever there is any changing load on the tranny while in OD. After it gets warmed up fairly well it also shudders, more so though at higher speeds like 65-70. The move from San Diego to Phoenix was very annoying.
I've brought it back to the shop three times. The first time they replaced the torque converter. The second time they said they didn't find anything wrong. The third time I test drove with the service manager; he confirmed the issue. Then the shop owner drove it and the senior tech drove it. Finally the senior tech test drove it with me, confirmed the issue and explained that it was a normal process (TCC lockup). He said it never worked properly from the day I bought it (I bought it brand new).
I've brought it to 5 different independent shops and a dealership since then. All confirmed that it was a problem and each gave me different explainations (and they all want to rebuild it).
It seems like the torque converter clutch isn't fully locking up, or staying locked. I really can't believe that this is normal. I've looked through tons of post but haven't found anything like this.
Has anyone experienced this or have a clue as to whats happening? Does anyone know of a reputable shop in Phoenix?
Thanks
P.S. This site is a lifesaver. I've learned so much in the past hour; I wish I'd found it sooner.
Thanks
