97 ABS question... | Ford Explorer Forums
97 ABS question...
andruxa
Edmonton, Alberta
'02 530iA TiAg
I redone my rear brakes recently, and have been noticing that my wheels squeal if I break suddenly. I am pretty sure they haven't done it before, and so I am thinking ABS is not functioning right... My quesions:
1) What could it be?
2) How could I easily test if ABS is working properly or not?
3) I generously sprayed the rear rotors with Brake Cleaner - could that have caused anything?
When I did rears I did them same way as fronts - jack up, take wheels of, take slider pins out, slide caliper out, hang on a piece of wire, replace the pads, slide back in place and bolt on. I did not replace pins, only greased them.
Thanks for your replies!
