ABS Question... | Ford Explorer Forums
ABS Question...
fliflicker
LA :/
94XLT
My left front brake is pulsing just before I come to a stop as if the ABS is getting a signal. It only does it on the one side... I have replaced the sensor and made sure that the rotor is correct with the proper ring. If I pull the ABS fuse, the brakes seem to work fine. Any suggestions? Can I do with out the ABS?
Forgot to mention... its a 1994 2wd explorer
