97 EB blend door ? | Ford Explorer Forums
97 EB blend door ?
tmn1220
1997 explorer
1997 ford explorer with automatic temp control, I've replaced the blend door actuator but a few minutes after turning the a/c or heat on air will stop coming out the vents. The blower can still be heard working. The automatic control module under the radio was also replaced. I get no code errors when running the EACT codes. The air does not default to the defroster when is stops coming out of the floor or dash vents. Air flow will go to defrost when I select it.
