97 explorer 4.0L SHOC idle surge | Ford Explorer Forums
Ronjm
Sydney NEW SOUTH WALES
Explorer XLT 1997 4L SOHC
hi I've been having trouble with idle on my ex cold or hot the idle surges from nearly stall to about 1200 rpm I have cleaned IAC , MAF and checked TPS for proper operation. Pulled codes and have code P1400 DFPE Sensor but I only just replaced this 800km ago. Any ideas.
Make sure you dont have any vacuum leaks, check all the vacuum hoses and connections.
Stuck egr ?
Can EGR be fixed or is it a new one needed.
Remove and clean with brake clean
Put a vacuum on it see if it moves
If all fails replacement
