sostahoe
- August 29, 2009
- tahoe nv
- 97 xlt
This has been ongoing for awhile, here is a quick history. original probplem was no start and replaced coil pack, good fix. 2 weeks later no start, -replaced coil pack and no fix, replaced crank sensor, good fix. Owner is now driving daily, but has intermittent idle surge that has been ongoing for months.
Now I am asking for help troubleshooting the surging idle.
It will surge from good idle too as high as 3500 and down too near engine die. (has even died). It will idle and run without surging while not in Park or Neutral (Loaded engine or driving). Also noted that randomly the tachometer will bounce without relation too the engine RPM, sometimes as much as 4-5 thousand above current engine RPM and then return to normal again. I have cleaned IAC valve. Removed and re-installed crank position sensor. I am getting no codes. I sprayed for vacum leak check and no rpm changes. I may be seeing incorrect coolant temp gauge readings as they seem way lower than I expected, but owner of vehicle says it has always been that way.
Any suggestions ????
