97 Explorer - Door Ajar Light On | Ford Explorer Forums
wcsd106
Marion, Illinois
1997 Ford Explorer XLT
Callsign
KB9IOU
Hello,
I have some questions about the door ajar switch on my 97 Explorer XLT.
First and foremost, should the door ajar switch be grounded when the door is OPEN or when the door is CLOSED?
The rear passenger door is showing ground whenever the door is open or closed, so that switch is most likely bad or in desperate need of cleaning.
Also, would unplugging the connector from the door ajar switch cause the doors to rear as open all the time or read as closed? I am planning on unplugging switches and plugging them in one at a time to find all my bad switches... if that will work.
Please help, this thing is driving me nuts.. dome light is staying on and if I lock the doors the alarm will go off after about 10 minutes since the vehicle sees door(s) as open.
Thank You
Disregard this post. I got it figured out. Both the front and rear door switches on the right side of the vehicle are bad. Reading ground all the time. I've disconnected both switches and it's working fine for now until I can get them replaced.
By the way, I found an excellent article for troubleshooting the door ajar light here:
http://sparkys-answers.com/2012/12/1997-ford-explorer-interior-lights-stay.html
