Andy Corwin
- January 17, 2016
- Chesapeake, VA
- 97 Exp 4wd 4.0L V6 SOHC
97 Exp 4wd 4.0L V6 SOHC I start the engine, temp gauge reads cold. I let it warm up just enough to where the temp gauge starts to move, then drive it just a few miles. Needle jumps to HOT fairly quick and the check engine light comes on. I turn on the heater to HOT, an the needle drops like a rock back to what I would consider normal and the check engine light shuts off. I can sit and idle and the gauge stays pretty much where it is. The coolant resivior was a little low so I filled it to the "cold" line after the engine completely cooled, but it happened again. Any ideas? I'm not a do-it-yourselfer, but before I take it somewhere I'd like a hint as to what it might be.
Thanks.
Thanks.
