97 Explorer radio buttons ? | Ford Explorer Forums
Sounds like your radio bulb is blown. Also might be a blown fuse. Theres a bunch in the fuse panel and even under the hood. Check your owners manual for what fuse is what see if its one of them. I would also check the lighting fuse while at it. If it ain't a fuse you'll have to take your face of your radio and replace the bulb. Good luck(hopefully its a fuse).
Sorry to bring up an old thread, but the reason your buttons arn't lighting up is the dimmer switch.
