cable2001
- August 2, 2005
- Lorain, OH
- 1997 XL
Hi everybody,
Last Saturday, I experienced some power loss with my '97 Explorer. I also noticed that a rattling sound that I had heard for a while seemd to be louder than usual (I had been told by several people that it was a loose heat shield).
Sunday, I completely lost power while crossing a bridge. I had the pedal to the floor and could only get it up to 35mph. On the other side of the bridge, my truck stalled and never started again.
My dad looked at it since I know nothing about vehicles. It was getting spark and some gas, but he thought it seemed like it wasn't getting a lot of fuel pressure. We tried using starting fluid to get it to turn over, but no luck.
We towed it to an auto parts store which is owned by a family friend who also is a part-time mechanic.
He checked it and found the fuel pressure was only 21 pounds. He said it had to be at least 30 to start, so diagnosed a bad fuel pump as the problem. We replaced the fuel pump and fuel filter, and the truck started for a few seconds, and then stalled and never started again. Fuel pressure was now at 42 pounds.
The next thing to be checked was the compression pressure in the cylinders. It is only showing at 45 pounds. The current theory is that one or both timing gears is bad. The problem is that this was quoted as a 17 hour repair, and I'm not confident that this is the problem.
I noticed a sticker in the owner's guide that said there was a problem with the front cam chain guide. Apparently, it may prematurely wear or break, and an extended warranty was placed on it. Unfortunately, this extended warranty ended last year.
Another tidbit is that I talked to a buy at another parts store the day it happened, and he said it sounded like a cam sensor went bad and was messing up the timing.
At this point, I don't know who to believe, so I welcome any input from you guys. I'd really hate to replace something that doesn't need replaced, all the while there is something else that is really the problem.
Thank you,
Dan
Thank you,
Dan
