97 explorer XL, stereo power booster??? | Ford Explorer Forums
custom103
toronto
97 XL
Hello everyone, :salute: I am replacing the factory cassette deck with a new cd player. I purchased the adaptor plugs for the conversion, but still not getting any sound from my speakers. The adaptor plugs were supposed to take care of everything - but did not.
*First off, where is this booster located and,
*what do i do to it to make it work and start cruising with tunes again?
Stereo power booster location
Your stereo amplifier is located behind the back, passenger side, trim panel. Yes and it IS a ***** to get at! Good luck:salute:
Thank you very much for the reply. I was afraid that was where it is located. One thing though...i have been told that it is not an amplifier but rather a booster. Apparently the amp only comes with the JBL deck. Also, do you know what wires to cut or re-route once i get to the amp/booster? thanks again. take care.
Is there a factory remote wire on the harness??
Well, i have not seen a schematic, nor was there a factory remote for the original deck, therefore i am fairly confident there is not a factory remote wire on the harness. Why?
p.s. thanks for the replies folks. keep em comin pls. maybe, together we can figure this out. :salute:
He meant remote wire in the harness to turn the amp on. Did you hook up a blue/white wire?
Head unit wires
At the back of your head unit you should have two plugs. The longer , gray, plug should have the following wires:
- Light Green/ purple strip – Memory power, hot all the time
- Black – Ground chasse
- Yellow/black strip – switched power
- Light Blue/ red stripe – illumination
- Black/light green stripe – radio ground
- Dark blue or gray – on power for your amp
The square plug is just your speaker wirers going to your amp.
:salute:
Wow! Thank you so much nomadtgif, oplitic, and aznboi3644. As it turns out the adaptor plug set that I purchased (pn#70-5600 from Metra) was NOT quite the "no brainer" i was told it would be (unless of course, you do this kind of thing all the time). The dark blue wire was not in the right position - nor was the black. On the adaptor I soldered the blue/white to the red, and the orange/black to the chassis ground. It is now working perfectly.
I am very impressed with this forum and will try to bring helpful knowledge to others whenever i can to show my gratitude for the help i have recieved. Thanks again. Take care. :salute:
glad to see ya got it. Sometimes the harnesses are messed up. just recently had thta problem on a BMW, the harness itself was wrong and the blue and blue/white were switched.
