Metalface
- December 25, 2022
- East Coast US
- 1997 Explorer XLT
Ok! So here's a wild one.
And before you say it. I am indeed suspecting the Crank Position Sensor first, but haven't gotten to it.
97 XLT SOHC V6 **No timing chain rattle**
We drove 2.5 hours to B from A, screwed around for an hour at A so add that to the driving, and then 2.5 hours back to A.
So we did about ~6 hours of driving. Parked it overnight, came out in the morning to go buy tires (lol) and it cranked but wouldn't start.
First thing I checked was fuel pump stuff:
-Can I hear the pump? (yes, not as much as usual, but definitely yes.)
-Fuel filter? (Replaced less than a year ago and the old one was ok. Was hunting a different issue which wound up being the coil had a crack in it that I couldn't see.)
-Fuel pump fuse? Looked good -- even swapped with another 20A, and still nothing.
-Fuel pump relay? Looked fine, replaced anyway.
Upon initial ON position with key, you can hear the pump start.
I checked the inertia / tip over sensor. Nope, looks fine, no burnt wires, not pressed out. It's totally all good.
Then I checked the fuel rail. Yep fuel. And yep, extra fuel comes out when the key is turned to ON. So we are getting fuel, or enough for it to at least try to cough.
Absolutely no firing of any kind is happening.
Then I checked for spark. No, no spark.
Okay, so why?
Looked into PATS stuff, turns out (says a thread on this forum) 98 and up has the key transponder, we don't even have one.. So it's not that.
No theft light.
Only had a code for a "Small evap P0422" and have had that on and off forever (bad carbon box) but we get fuel to the rail, so..
No flashing theft light. No theft light code. So hmm..
Tried starting in Neutral, nothing there either. Had my neighbor pull the throttle to ignore the TPS and still nothing even in neutral. I had not yet discovered no spark, but that's what I checked next.
Tried unplugging the main computer and plugging it back in. Yeah.
So, now I'm trying to do some mental detective work. Ok, did it behave weird on the drive? Has it been weird at all?
Nope! No weird behavior. Always has had a tiny little misfire that hasn't been out of spec to trigger a code, and that's only at idle. I'm chalking that up to being nasty old injectors among other 25 year old vehicle issues.
So I'd really go as far as to say, we parked it, and it left the chat.
I had initially suspected we got the fuel pump (((or SOMETHING... we will probably find out what...))) really hot and then because we didn't idle after our epic journey, it didn't get a chance to cool itself down. But at this point, if the fuel pump is damaged, I don't care to worry about that yet, because no spark.
So it boils down to now that we have:
-Cranks just fine.
-But.. no spark....
-Did not overheat. 100% certain. Has never overheated.
Also did not fade or shut off or anything!
-Never had timing chain noise or rattle.
-NO theft light.
-No theft light codes or flashing light.
-No PATS system to begin with and our key certainly never had a transponder chip.
-Completely fine running conditions prior to parking overnight. No fading no hesitating no weird idle no loss of power no overheating, nothing.
-No rodent activity and a very well greased frame that pests would hate, parked in a location where rodents wouldn't be interested anyway..
-No tripped inertia sensor.
-Fuel getting to rail.
-Stock Anti-Theft with No Issues for 3+ years that fully functions as from factory with no modifications at all.
And, here's things that have been replaced since we got it at 120 ish K miles (now at a little over 200k) when we were hunting down what was actually a cracked coil / cap:
Replaced sensors and etc that might have to do with something like this:
-MAF sensor
-Intake manifold gasket
-Fuel filter
-Throttle Position Sensor
-Spark plugs (we saw some truly horrible things down there. we won't speak of that.)
-Coil / coil "cap" ****but not spark plug wires.****
-other things I may be forgetting and will edit here if I need to!
So. In my life experience I've learned that heat cycling the living hell out of parts and computers (because I have an IT and electronics background before anything...) is not awesome for them, especially after already existing near a warm engine for 25 years. I really do suspect it to be the Crank Position Sensor. Do we know if it is prone to taking a massive dump after a certain # of miles, or excessive wear?
And, my biggest question..
Why the hell would it be completely fine before parked, and then wouldn't start with no spark in the morning?
Thanks guys! Know that was a lot but especially when it comes to completely out of the blue stuff like this, forensic / detective work helps A LOT and knowing what is and isn't wrong helps narrow it down. I do fully intend to replace this sensor. You'd have to rip my Explorer out of my cold dead hands before I got rid of it or didn't fight to get it back running again. Especially since it's never had issues like this before. Also, chance of it being the coil...? Could replace. Is that likely? I figure it would be "as likely as any other truck" but then I think, maybe there's something we all know here that I haven't been aware of yet.. haha. Ty for any replies and ty for the time and thought spent on my silly little issue.
Okay, so why?
No theft light.
-Cranks just fine.
-But.. no spark....
-NO theft light.
-MAF sensor
-Fuel filter
