97XLT TT - Quick question | Ford Explorer Forums
jsammari
Marlton NJ
1997 Explorer XLT
Quick question. Why must the truck be put on jack stands for the TT lift? Can it be done with the wheels on the ground or is that like lifting the truck with my hands...:)
Because it takes the load off the front suspension. It's much easier to do that way.
The official procedure in the Ford Service manual has you do it with the wheels on the ground. The manual says that when going up with the suspension, no settleing time is necessary. When going down, it recommend going down past where you need to be and then come back up to the proper height. It says that it can be done with the wheels off the ground, but it recommends taking the vehicle for a drive over varying terrain types to allow the suspension to settle. Then you have to take another measurement and make another adjustment if it isn't right. The last several times that I have adjusted mine, I have done it with the wheels on the ground using my 1/2" drive ratchet and 13mm socket. I have no problems turning the bolt and I am far for overly strong.
hmmmm..
Thanks for the help. I'll try it with the wheels on the ground.
Correct, leave it on the ground. Spray it with some WD-40 to make it easier to turn the bolts. A 1/2" ratchet will aslo make it much easier, but you can use a 3/8" ratchet.
Only reason some jack the vehicle is to make it easier to turn the bolts.
