JetTech1966
- December 9, 2009
- Hapeville, GA
- 98 XLT 4.0 OHV
I know this is my first post gents but I've got a problem with my baby that is kicking my butt. It's a 1998 explorer, 4.0L, OHV, 2WD that is giving me fits and the ECU refuses to give me any codes. It will miss and hitch under load and I've replaced or done everything I can think of to do. It starts and idles fine, it will run WOT fine, problem occurs when I'm going up a hill or part throttle, slow or fast. It will miss a little and sometimes just fade in and out like there is something tugging on it. Here's what I've checked and done.
1. Replaced the fuel pump and filter.
2. Replaced plugs and wires.
3. Replaced the coil pack, no help and was lucky that autozone took it back.
4. Replaced MAF and IAT from a donor vehicle.
5. Unhooked the EGR, no help.
6. Replaced the DPFC I think it's called.
7. Had the transmission put on an analyzer, no problem.
8. Checked voltage. Good.
9. Checked voltage on the TPS while opening and closing it slowly, checks good.
As you can see I'm pulling my hair out with this ocassional miss that only occurs under load, hot or cold. I can make it miss by stomping on it in park or neutral so I really don't think it's a tranny problem. It shifts great all of the time. I'm leaning towards a faulty fuel injector but I sure could use some ideas because the darn ECU won't even give me a hint. Everytime I plug my code reader in, PASS- No codes found.... grrrrr
Believe it or not I've been a master tech since 1985 but I don't do it for a living. I work on commercial aircraft for a living so I'm not quite up on the inside knowledge for these vehicles. Does anyone have any ideas? I have a digital VOM meter and know how to use it, just please point me in a direction and I will investigate it to no end.
Thanks all,
Dale
Thanks all,
Dale
