kjgces
- March 27, 2009
- bethlehem,pa
- 98 explorer 4.0 sohc 4wd
guys, if the internals of the two transmissions are identical, as some have stated, then why do the older units get bands adjusted to 1.5 turns vs 2/2.5 for the 5r55e. is this contributing to the 2-3 flare problem? anyone who has seen the internals of this trans might be able share a reason for the adjustments to be different. that much difference would make a lot of change assuming the servo strokes are the same... thoughts.
