rlp71068
- January 23, 2010
- 1998 ford explorer
Hello everyone,
currently doing the upper and lower intake gasket replacement, was leaking at the front drivers side. Well the front intake to head bolt was corroded and came out by hand, half of it. Im not sure if i can turn it out by grasping the small amount that is above the surface of the head, so ill probably have to drill it out and do the helicoil repair. does anyone know what size bit i should use and what helicoil size i should get or do you get the helicoil set first?
