98 explorer rear abs speed sensor bolt size ? | Ford Explorer Forums
98expo
Hey guys I had my abs light on and finally got it scanned, says its the rear abs speed sensor. I looked under the car and doesnt look too hard to replace but its hard to tell what size bolt, that holds it in place since its on top of the diff. Does anyone know what size it is ? any tips of taking it out ? thanks
8mm or 10mm dont think its a 11 or 13mm.
one of those sizes. the o ring on the pumpkin might make it hard to pull out once the bolt is out.
also check the wires by the sensor. they tend to also brake around the left spring.
10 mm did mine 3 weeks ago, make sure you get the sensor all the way in
10mm or 3/8
