emfjsullivan
- July 29, 2002
- herdnon, va
- Navajo (Explorer Spt) '93
I have a problem with my internal lights (domes, courtesy) and ground illumination lights - they don't come on! The internal lights (domes only) do come on if I move the instrument panel dimmer to all the way on, but when I open the door manually and when I use the keyless remote, no lights (internal or external ground illumination) work.
I'm thinking it may be the interior light relay which is located in the relay module. In the diagrams I have, it looks like it is behind the Instrument Panel. The question I have is what is the easiest way (if there is one) to get to the relay module to check to see if the interior relay is the problem?
Any suggestions welcome!
