davew_
- November 21, 2013
- 1998 Explorer XLT
To start things off approx. 2 months ago I bought a 98 explorer xlt used for 1500 bucks and couldn't be happier. I did however start having an issue when cold starting the truck after 8+ hours of not driving. The issue im having is that it will crank, start and immediately die. Usually on the second or third try it will stay running and seem fine. the other day I was about to drive and the truck repeatedly started and died, the only way to keep in running was to hold my foot on the throttle slightly. If I rev'ed it, it would climb in rpms no problem and then die. after around 15-20 times, and almost every time letting in run for 20-30 seconds with my foot on the throttle and consistently dying, it started to idle on its own. a few times on initial start up I would hold the key in the start position and it would still die, I did this to rule out the key switch, also when its running and driving I have no issues, so I was thinking of ruling out the fuel filter as its not sputtering or idling rough when warm. The truck seems to be very well maintained and reliable, except for this one issue, if anyone has come across this issue before or has an idea of what to check, im all ears. thanks
