Chels520
- January 21, 2010
- Dallas
- 1998 Explorer xlt v8
I received a couple check engine codes...one was o2 sensors.(replaced-code fixed)
2nd code was misfire. (replaced spark plugs). Friend who replaced said plugs needed replacing, bad gap, but were "tan" & wires looked good & didn't think they needed replacing.- code fixed!
After all that, I got the folowing code:
P1309
Misfire monitor disabled,
Verify cam sensor is synched,
ECM failure,
Verify input sensor parameters are correct.
We replaced the cam sensor & light came back on. Friend is thinking it could be the computer. Just wondering if anybody had suggestions or had similar problem. Thank you!
P1309
ECM failure,
