98 Headunit change, now no clock? | Ford Explorer Forums
Curtis629
Flowery Branch, GA
2000 Explorer XLT
I've got a 98 explorer that that had the Cd/Cass head unit with the RDS button but no sub in the back. The display went out so I swapped it for a working CD/Cass unit from a 2000 explorer without the RDS button. Now on the new head unit I have no clock and when I push the clk button the display says "No clk". Is there an updated harness to make this head unit work or do I need to search for an RDS headunit to get everything back working again?
Thanks,
From the audio guide:
Standard Dual Media Radio
Setting the clock (*****if equipped*****)
To set the hour, press and hold the
CLK control and press:
< to decrease hours and
> to increase hours.
To set the minute, press and hold
the CLK control and press:
< to decrease minutes and
> to increase minutes
Maybe your head unit does not have the clock.
Hope this helps in some small way
Scucci
No need to create a new thread for the same question, just bump the first one, did you check what I told you?
ConsTNTpower.....
Check that yellow wire is connected to harness............that is the"consTNT' power to clocks, memory , etc.
