98 Mountaineer plug # 3 access. | Ford Explorer Forums
acumenet
Bainbridge Island, WA
98 Mountaineer 4.0L SOHC
How do you change plug number 3 (Riders Side Rear) on a 98 Mountaineer other than removing the whole air conditioning condenser unit..... help!
thank you
remove wheel
From what I've read most members remove the wheel and inner fender flap. Make sure that you have a swivel spark plug socket of the correct size. Do a search and there are several step by step threads, maybe even a video.
It's the easiest way to do it. Once you remove what 200Streetrod mentioned the plugs will be right in plain sight.
welcome
Welcome to this forum! I've moved your thread into the stock 95-01 section. Use a long wobble extension with the socket to get into tight places where a standard extension can't go. It will provide a slight angle.
