SparkyGT
- July 6, 2009
- Alberta Canada
- 97 Explorer Limited 5.0
My 98 explorer is running real rough when cold, down to freezing temp here now.
What it does is go from about 1500 rpm, then down to 500, and hunts up and down, sometimes stalls out, so i have to play around with the gas pedal to keep it running.
As the temp got colder this got worse over the last few weeks
Heres what i have done so far
1-Cleaned IAC with electronic spray
2-cleaned MAF sensor also
3-checked IAT sensor(the one after the MAF)
4-changed out TPS sensor - on advice from stepbrother
5-no difference with new TPS
6-checked codes with code reader, Lean bank left, and catalyst when i checked book
7-erased codes, new ones showed up Lean bank left, Lean bank right, neither turned on check engine light
the check engine light has come on once, when i plugged in the scanner, the code wasnt there for some reason, or i hit the erase by accident
i will update as soon as i get this thing running better
