syn-
- July 27, 2006
- orlando, fl
- 96 xlt - wip
I just totaled my 97 sport and despite all its problems I enjoyed the truck (reliable). Had 4 12"s @ 2k @ 1ohm w/ 4g + a yellow top optima. My lights and hud would dim lightly normal and heavy when I got greedy and wanted to hear more bass. Not sure if it was related but I would often have to turn and hold the key to get it to start after long sit periods (overnight for instance or all day at work). I was happy with the sound, but I am curious to know on the new exploader if I should ante-up to 2g or 0g? I bought reducers to do the job going to the amp, but have learned that larger wire will also need a separate battery (which is ok, because I still have my optima from the previous truck). Since I am already half way there (only needing to buy the wire kit at this point) is the larger wire worth the investment? what are some pros and cons? First thought that comes to mind is the subs having more available wattage so would I run a higher risk of over-pushing them?
Note: I also plan to put in HID's so I want to also make sure that they do not dim (unless the ballast is what will be responsible for that?)
sub + amp spec:
audiobahn hct1500
2 12" kicker cvrs
2 12" kicker l5 solo-barics
sub + amp spec:
audiobahn hct1500
2 12" kicker cvrs
