98 xlt 5.0 awd throwing codes | Ford Explorer Forums
desertrig
1998 explorer AWD
i have a 98 xlt 5.0 awd and its throwing a 1127 and 1116 code. i believe the 27 code is a o2 sensor heater to far to be tested code and the 16 code escapes me at the moment. i was just wondering if anybody had these codes thrown and what they did to fix them. it originally started off as p0125 codes, hooked it up to my buddy's versus computer and it came up with this. i had swapped all the sensors for the 0125 code but the temp sensor on the gauge cluster still doesn't work. just hoping somebody out there has a solution. thank you. also, the tranny in my rig is the 4r70w, correct? i wrote in here a couple of months ago about a driveline vibration and i forget who responded but they were correct in saying it was the front driveshaft cv. replaced it and the truck drives smooth. thanks for that.
Did you change the Engine Coolant Temperature Sensor?
yep, changed the sensor that taps into the thermostat housing and the sensor under the bracket the coils sit on.
