UKwinsagn
- June 14, 2010
- Williamstown, KY
- 98 XLT
I'm gonna try to make this short and sweet. Let me start by saying that in the winter this thing runs like a champ. The summer is another story. I have only noticed it on days above 80 degrees but the darn thing will want to drop down to an idle while im goin 70+ on the highway! I can only push the gas pedal down about a half an inch (which usually lets me maintain @ 45mph) which isn't that great. If i give it any more gas than that the rpm's drop to @ 500. If i put it in nuetral and turn the key off -- then restart it, i usually get enough power back to make it up the next hill then it will bog down again. I replaced the fuel pump/filter and the IAT sensor and the plugs/wires are @ 6 mo's old. Fuel pressure in the driveway is a constant 30psi and will go to @ 38psi when i rev it. I checked the MAF and the voltage seemed to be within range and voltage increased slowly as i opened the throttle. Does this motor have a fuel pressure regulator? Because when i go to look it up at Autozone, it says there isnt one on this vehicle. The DTC's all show lean conditions on both banks and a gross evap can leak. Any help or guidance will be greatly appreciated.
