'98 XLT Strange noise decelerating | Ford Explorer Forums
jawns
Richmond VA
1998 Explorer XLT
Hello Explorers,
My daughter has a 1998 Explorer XLT 4wd AT V6 SOHC, purchased in 2005 with 120K miles, that I maintain as my skills allow. I've put brakes, shocks, filters, plugs, etc. on it and it has been a reliable vehicle.
She reported that it had developed a strange noise last night at the end of a 2 hour road trip. She said that it made a loud noise when the accelerator was released after reaching 50 mph and that the noise disappeared if you got back on the gas.
I was at her house for Christmas this AM and after lunch installed one of my gifts for her (new hood support cylinders) on the truck and then took it for a diagnostic drive.
Sure enough, got up to 50 mph, released throttle, and a fairly loud noise seemed to be coming from the dashboard or floor area and stopped when throttle was pressed again. We made it repeat the noise several times and turned into a parking lot and put it in Park. My first thought was speedometer cable or speedometer because I drive a Ford truck on my job that has a screeching speedometer, so I was going to try to disconnect the cable. I didn't have a flashlight or tools and quickly knew that it would be futile.
When I shifted from Park to Reverse, the noise started and I engaged the parking brake and got out of the truck to try to locate the source. It is not coming from inside the exhaust pipe. It is loudest in the area from the radiator to the rear of the front seats. It may be louder on the driver's side, but not by much. When the hood is raised, the noise seems to be coming from below near the firewall. I tried repeatedly but could not make the noise start again without getting the vehicle up to speed.
The noise is difficult to describe but I'll try: it's a mixture of a buzz and a whir/whine; there's a slight lag between throttle release and the beginning of the noise; it's a mid-range pitch that stays constant in volume and pitch until it stops at about 10mph or when you press the gas; it seems rotational in some ways but doesn't change as the vehicle slows or when the brakes are applied; it's about the same volume inside the cab and out; the noise is loud enough that it can't be ignored but not overwhelming. It sounds like releasing the throttle starts something spinning and it continues at a constant speed until you get on the throttle again.
My gut tells me that the high vacuum under deceleration is engaging something or causing an effect like blowing a trumpet mouthpiece and the only thing that stops it is to decrease the vacuum by opening the throttle.
Has anyone experienced or heard of anything similar to this? I've heard lots of vehicle noises, but this a new one for me. I really don't think it's coming from the drivetrain because there's no effect on the way the truck drives or feels (no vibration).
Any input will be welcomed--I'm going to drive it more tomorrow and look for more clues.
Doug J
Only thing I can think of right now is the transfer case. Question for you: do all four tires match EXACTLY? It is well known that mismatched tires or treadwear can cause noise from the transfer case, when you let off the throttle at highway speeds. Internal wear in the transfer case can cause this also.
PS: That truck has no speedometer cable, it uses a sensor instead.
Thanks drdoom. The tires do match. Will drive it tomorrow for a longer time and make notes. Did not mention previously that the truck has not been driven in 4wd high or low since my daughter has owned it.
OK here's the update. I went to drive the truck today, put it in R to back out of the driveway and the noise started immediately, much louder than before. Put on parking brake and crawled around underneath and it seemed to be coming from the converters or transmission. Noise only occurred in reverse. When I tried to back out of the driveway, the truck didn't move---oh no!!
I'm letting her borrow my 1997 F250 while I call transmission shops and junkyards and try to advise her about what to do. I'll be searching this site for "no reverse loud noise" also. If anyone can direct me to helpful threads and advise me about the degree of difficulty of swapping the transmission I'd be grateful. I can see that the exhaust system will need to be disassembled.
Thanks Doug J
Any update to this? Mine has a weird nose underneath me when I let off the gas and am above 40 mph. Then when back on throttle it stop and when on the brakes. Gonna try disconnecting front driveshaft to see if it fixes it. Tires were all replaced brand new mid-December.
Steeda, do you have the grinding noise?
I was going to suggest U-joints, but... Ouch. No reverse?
