dkam
- August 6, 2007
- Golden, CO
- '99 XLT
99 Explorer SOHC with 167k. Fuel cutting out, waiting 20 minutes then ok,
only to have it return.
I am having a strange fuel delivery problem which may or may not be associated with heat. I have searched but cannot find anything similar, at least with the terms I am using.
Drives fine, motor runs great, driving for a few hours in hot weather, I am stopped at a light and suddenly the idle begins to get rough. The fuel is cutting out and the motor starts surging. Up and down through the rpms, by about 500 rpm but still maintains idle without stalling. I step on the gas and it hesitates bad and about stalls. After a push to the side of the road and sitting awhile thinking it over, I bang on the fuel filter and it starts and runs fine. Drove it home and replaced the fuel filter and it's been fine in any weather.
I had no problems for a month....until.......we drive 340 miles on a road trip with no problems at night. Coming back about halfway up a decent grade, it starts again. This time I have the r's up trying to make it up the hill and it starts surging at 3k (no idle issues). Pull over, bang on the new fuel filter and still struggles. About 15 minutes latter of waiting and three short banging sessions (stop banging already). Starts and runs fine all down hill in 90 degree weather for another 130 miles. Just outside of town, it starts again. WTF? Pull over, loose hope, carry on the silly banging just in case, all for around 30 minutes, just about to give up for a tow and I'm on the road.
I pulled of immediately at the next exit, drive two blocks to an AutoZone. I have them pull the codes and ??? No Codes ??? Not even anything in history and it's had the same battery since I owned it.
This is good and bad of course.
Can my fuel pump act this sporadic? Wouldn't it just stop working like other Fords I have owned? What else would cause this kind of behavior? Like maybe some sediment in the tank and another clogged filter? I just don't get the on and off behavior.
Regulator, filter, fuel pump, or the dreaded electrical?? I of course don't want to rebuild the fuel system part by part. Especially when I am thinking about what part to buy next on the side of the road.
Ideas? Thanks!
I posted this on the ford truck forum and had a suggestion to replace the filter. I still have not replaced the filter and am using the exp to commute.
Ideas? Thanks!
