aberrant
- July 27, 2015
- 1999 Ford Explorer EB
Hello,
I'm new here and have a 99 Explorer that's having a few issues. Instead of posting a new thread for each one, I'll just list them here.
1. The truck seems to have trouble starting at times. It had been sitting for a few months, not running. After replacing the battery it seems to be somewhat better, but still has trouble starting once it has sat for a day or two. If it's started and driven during the day, it doesn't have trouble starting again that same day. I was initially suspecting the fuel pump, but I can hear it run when turing the ignition on. I've also checked all fuses and they appear to be fine. Haven't tested any relays however, as I'm not sure where to start. Interestingly, it will usually start up on the third try or if I cycle the key on and off a few times. My next step was to replace the fuel filter as it is due for a new one. Any other things I should look at?
2. This explorer is equipped with the automatic ride control. It used to work fine, but now I never hear the compressor nor see the suspension level out. I checked the fuses for this system and they are fine. Again, did not check relays as I'm not too sure how to do this. I was able to locate the compressor, which is above my spare, but the only thing I hear when closing all doors with the ignition on, is a clicking coming from the compressor area. Any ideas what this is?
3. There is some sort of clunking coming from the front end. It is usually more evident when braking and coming to a stop and when turning sharply. I was told the lower ball joints have excessive play, so this is most likely the cause, but wanted to see if anyone had any other opinions.
4. The steering wheel is making a whine noise when turning left or right. It's faint, but there. Is this something I should be concerned about? Power steering fluid is topped off and always has been.
I've already successfully replaced the blend door actuator, battery, hood lift supports, fuse for the horn (controls chirp for alarm as well), and the vent hose on the rear axle (it was rotted off. found it when inspecting the compressor unit). Unfortunately the truck needs brakes, new tires (starting to rot, but still have lots of tread), a new windshield or seal (leaking in the top corners), rear lift gate hinge, and probably new lower ball joints. I love the truck, but these are a lot of costly repairs. The truck has about 116k on it. Engine and transmission seem fine, but not sure if they will give me trouble down the line. Are these pretty reliable? The truck has been great it's entire life (original owner), but I can see now it's starting to show it's age.
Also, here's a pic of what I believe to be the evap canister, but it connects to the compressor above the spare. Also, one side is open to the atmosphere and the end looks chewed up. Is this how it's supposed to be?
https://www.icloud.com/sharedalbum/#B045oqs3qTQqGW
Thanks for any help. Cheers.
