haaworld
- November 17, 2006
- houston
- 99 limited
Hi all, I recently removed my front seats to have them reupholstered . After reinstallation, my driver seat will only move in one direction. Meaning it will move forward but not go backward, front tilt will move up but not down, rear tilt will move up but not down. Thinking my switch had finally bit the dust, I bought two new switches and I am getting the same results. When I bypass the switch and module, all 3 motors move in both directions as designed. I have studied the memory seat wiring diagrams and confirmed I have hot(BK/WH) and a good working ground(BK) to the seat. I have confirmed fuse at module is good and all connections at module are seated. I have search this forum but have not seen anyone have a problem like this. Seat worked fine before the R&R. I am at a loss here, any help would be appreciated.
