- February 13, 1999
- Location
- Tampa, FL
- Chief GPS'um and Still Lost Native Texan
- '99 EB 4x4 "Herc" RIP
I am fairly certain that this has been addressed here before but a search brought up so many links that I can't find the answer within the mountain of information on this forum.... so here goes with a new thread.
My trailer lights use the same bulb for brake and turn signals, while my Explorer has the yellow turn signal light separate from the red brake light. My right trailer brake/signal light does not work. The less-bright running/night light setting does. The brake/signal light is controlled by the green wire coming out of the Explorer's trailer wiring harness. I have checked the two foot section of wire that plugs from the wiring plug that is up in the drivers side rear cubby hole and mounts to the back of the bumper and it is good, so there is no short in that easy-to-replace item. The problem is somewhere within the Explorer's wiring that sends the signal to the green wire in the trailer wiring harness.
I did a partial fix by splicing into the right rear turn signal wire and running a parallel wire all the way across to the green wire on the drivers side trailer wiring harness so I have a right turn signal now... but since the turn signal light and brake light are separate on the Explorer I still do not have a right brake light. I can't fix that by splicing into the brake light because that would link the turn signal and the brake light together through the trailer wiring, operating both the right signal and brake light on the Explorer any time I used either one.
I think my solution is to know how/where to tap into the green wire circuit upline somewhere and splice in there (?)... or find an alternate way to get the right brake and turn signals to work correctly both on the Explorer and the trailer.
Does anyone know the solution?
