V8-X
- November 6, 2002
- Edgewater, CO
- 02 F-150 S.C. Lariat FX4
99 X - 5.0 - AWD - Auto Trans
All started with bad #4 spark plug.
In June 2002, my engine started to mifire & the CEL came on. This was determined to be the #4 spark plug. Which I replaced and from there the CEL turned off and has not come back on. Since then I've had a loss of power/flat spot and rough idle (first 5-10 mins of driving warm or cold start).
I've taken the truck to Ford twice and to two independent shops. Ford couldn't find the problem, stating everything shows within operating spec ranges. One independent shop couldn't find anything, while the other stated the rough idle was the IAC & the loss of power/flat spot was the FPR. I have paid $391 + tax in diagnosis fees alone to find no cure.
Since having the truck checked 4 times, I have replaced the following which has not corrected either of the problems. All replacement parts are Motorcraft or Ford parts:
IAC, FPR, EGR, PCV, Fuel Filter, all 4 O2 sensors and all 8 plugs & wires. I have cleaned the MAF/MAS and I have purhcased a new TPS, which will go in this weekend.
The symptoms are most noticable under the following conditions: accelerating with RPM's under 2000, accelerating while on an incline, accelerating from coasting or during light acceleration. The engine & exhaust tone are slightly deeper/louder than before the problem started. At times the Trans sounds like a Manual trans when it is in to high of a gear, but this is an Auto trans. I do not believe it to be a bad Cat., as the backpressure tests come out ok. When over 2000 RPM's, the majority of power is there, but I still have 4 banger Geo's passing me and I have the 5.0V8.
Any thoughts, advice, suggestions and/or help would be greatly appreciated. I've been trying to cure this for the last 5 months, and nothing has worked. Ford seems as clueless as I am.
Thanks in advance for everyone's input on the possible solutions
