hello everyone i am thinking about doing a torsion twist all the way and getting a 3inch body lift to fit either 31s or 33s if theyd fit? i cannot find a kit to be put on my sport i heard the 99ranger 2wd kits would work. i just need a little info as to which kit would work.
with the tt shackles and 3in you should be able to fit 33s with little to no rubbing since you have the sport which has larger wheel wells and if i am correct the bl is the same for both 2dr and 4dr its the pa-883 body lift for the 3in model also Tarheel085 here is selling a 2 in for 150 bucks or if ya want a 3 in look on ebay i saw some there a few days ago for a little cheaper than normal also i do believe that there are a few guys that were willing to trim and with the 3 in bl and 2in tt and shackle they are running 35s and a 31 will fit stock
hope this helps and try and search cause there is a new thread every other day so theres alot on this site some even with the how to install this kit
