A.B.S problems | Ford Explorer Forums
A.B.S problems
  • Thread starter Thread starter Ron
  • Start date Start date
R
Ron
I have a 93 sport and a 95 econoline(both bought new) the abs light comes on in both trucks at intermitent times for no rhyme ,reason or pattern.the dealers claim its not a common problem and they have worn me down till i gave up ! will i have to live with it or is there a fix !I find it hard to beleive i'm the only one,as both trucks do the same exact thing. otherwise both trucks have been relativly trouble free !
First thing to check is if there are any ABS codes comming up when you check it with a code scanner. There is a cheep (18$) sensor in the rear end housing and that may well be the culprit. --Bret
