A/C blend door questions. | Ford Explorer Forums
erald01
canton, mi
1998 Explorer 5.0
A few questions about the blend door: Is the door inside the evaporator or outside? How easy is it to be replaced or fixed? Does it run off a motor or vacumm lines? Thanx in Advance guys:D
The Door is in the Plenum. It divides the box into to seperate inlet air paths. Coming from either Cold (A/C) air side of the box, or from the Hot Air (Heater) side.
Depending on how you go about doing it, it can be a 4 hour job, or a 5 min. job. Search for all the methods that people have done to 'repair' this problem.
It is controlled by an electronic 'motor'. Ford calls it a 'Servo'. No Vacuum is used in the control of the Blend Door.
Ryan
