areevet
- June 1, 2010
- Zeeland, MI
- 2002 Eddie Bauer
I bought a 2002 Eddie Bauer this past winter and didn't think to check the A/C, but who would in the middle of February in Michigan. Well, now I need the A/C and it's just blowing warm air. So, I purchased a recharge can of
R134 with a pressure gage attached. I hooked it up to the low pressure side and discovered that the pressure was only 10psi. So, I had the A/C on full blast and started to recharge the system. I put enough R134 into it to get the pressure in the appropriate recommended zone (35-40psi). I figured this would do the trick, but it's still blowing warm air out all of the outlets. Just because the pressure in the system is at the recommended levels and the blower is working, does this mean that the A/C compressor can still be bad? If so, how big of a job is this for a "do-it-yourselfer"? I'm very mechanical, but wondering how big of a job is this on a 4.6L for a guy working out of his garage and dodging bikes, toys, buggies, baseball bats, etc?
