The a/c system might be low on oil...
People tend to forget that the a/c compressor does run under some settings other than max cool...And the compressor has its lubricant inside the system but the only way the oil gets to the components of the compressor is to run the a/c compressor...
The oil flows with the refrigerant and running the compressor 10 minutes a month should get the oil circulated throughout the system...Here in Texas I run the a/c system pretty much year round...I will run the heater when the temps drop under 30-40F but that is not that much...My a/c system is still running perfectly after 12 years...So far[knock on wood]...
Now if any of the hoses or connections seem to have an oily or dirty buildup on them then you have a leak and guess what comes out of a slow refrigerant leak...Oil and that is why dirt is attracted to that spot...If you have lost oil through a leak then the system, when it is being run, may be low on lubrication and eventually that will cause noises, squeaks, and a locked compressor...
Unfortunately there is not an easy way to check the oil level in the a/c system...If you have lost oil, realistically, the only true way to know what is in the system is to recover the refrigerant, drain the oil out and replace it with the correct amount...You probably have a leak anyway and this would be the correct time to fix it and bring the oil amount back to spec...
Some people will just add an oil charge to the system and let it go which will introduce oil to the a/c system but having too much oil in the system will cause it to not cool as well and can cause a compressor lockup depending on how much oil is flowing through the compressor...
With all that being said...If the noise you hear happens with the compressor NOT running, the noise is coming from the compressor clutch unit, probably from the bearing that holds the pulley in place...If so the compressor clutch can be replaced without distrubing the refrigerant system...The clutch is held onto the compressor by a center nut and a snap ring...
