A/C Idle issues... IAC? | Ford Explorer Forums
Y2KFirehawk
Lehigh Valley, PA
'22 Bronco Wildtrak
My 2001 Sport has 64k on the clock. It idles fine without the A/C on. When running the A/C it's no problem in drive. As soon as you shift to neutral or park the idle fluctuates 4-8 times and then seems to be OK. I had it stall once between going from drive to reverse... :confused:
From reading around, I'm thinking perhaps IAC? Is there a write-up of how to clean it? I also am thinking it could perhaps be "fast cycling" the A/C? How over should I hear the compressor kick on/off?
Thank you guys!
Bump?
yes there is a thread on how to clean it...yes, very likely it could be that...
turn off your a/c ...does it still happen?
