A/C Issues w/my 2005 Explorer 4.0 V6 | Ford Explorer Forums
ExplorerRider
Cape Girardeau, Missouri
2005 Explorer XLT
Hey... Okay, my Ford's A/C blows somewhat cold if you only have the air set to blow out the front vents of the truck (manual knobs BTW) & while it does well on, say, a 75 to 85 ° day... If it's 102° w/the heat index, while it's enough to be better than the ole '4×70 air conditioning' aka 4 windows down @ 70 mph, it only keeps you more comfortable than if you have nothing, but certainly doesn't blow nice & cool... UNLESS(!) you use the overhead knobs to turn on the rear console vents & rear overhead A/C vents... Then EVERYTHING blows cold enough to get ya chilly if you're sitting up front & have shorts on! Also, if front vents turned on - even on a 80ish degree day... If you're sitting & idling, the air gets somewhat warmer to the point it's BARELY more comfortable than nothing! But again... So long as you're driving at 55 mph or more AND have the rear overhead vents turned on along w/,the front dash vents... Meaning EVERYTHING BLOWING AT ONCE... The sonofabuck will damn-near't freeze ya out! So what in the world gives??? Help, plz! Thnx in advance!
R
