A/c Problem? | Ford Explorer Forums
A/c Problem?
pitbulldell
Orlando,Fl
95 XLT
Every now and then my A/C will stop blowing cold then 5 min later its cold again.Sometimes it will go all day working fine.then other days it will be blowing ice cold then just all I get is warm air then back to cold off and on all day. any suggestions?
Two thoughts that come to mind are blend door issues, and a low charge and/or defective low side cutout switch that is freezing your evaporator.
thanks, some one else mentioned blend door problems.
TURNS OUT ITS A BAD A/C CLUTCH. WHEN IT STARTED BLOWING HOT i HIT THE FRONT OF THE A/C AND CLUTCH KICKED ON THEN COLD AIR.I WILL REPLACE THE CLUTCH ASAP
