A/C problems | Ford Explorer Forums
A/C problems
Robot Lincoln
Grafton, MA
95 XLT
I just went through the process of recharging my A/C and replacing the clutch on the compressor, and my A/C is working fine, but for some reason my fan is stuck on the defroster setting! I've checked all of my fuses and can't figure out what's wrong. Can anyone help?
By saying that your fan is stuck on the defroster setting, I assume you are saying that air always blows out the defroster vents, and not the front panel or floor.
1995 and later models had rotary controls and a vacuum selector switch controlled the opening of the door in the ducting that directed the airflow. Either you have a vacuum leak or a broken/disconnected control hose.
Regards
Thanks for the info
I was moving around a lot of hoses and connectors yesterday when I was installing the clutch, so that suggestion makes sense; I'll whip out the old haynes manual and track them down. :roll:
