A/C stops blowing when accelerating | Ford Explorer Forums
Jocharflet
Chicago, IL
2003 Ford Explorer XLT
The air comes out cold, no issues with temperature. The air pressure is a bit low, High is barely stronger than low. I can deal with the air pressure, but the fact the air stops completely when I accelerate is a problem. When I lay off the accelerator, the air will start blowing a few seconds later.
Anyone experience this? Know how to fix?
2003 Explorer XLT
Start looking for vacuum leaks under the dash
2003 Explorer XLT
I also have the same problem at that time i called the Air conditioner repair guy to check it and they told me that the problem is in the compressor valve, they repaired it and after that i never had they very problem with my AC unit.
