apenland01
- September 11, 2009
- Tucson AZ
- 2005 Eddie Bauer V8 4.6L
I have searched the entire AC section, but haven't found anything I can sink my teeth into.
2005 EB V8 with dual cooling class 3 towing. About a year ago, occassionally, we started noticing a very short (less than one second) growl when we first started the vehicle, which it had never done. We could never reproduce the problem for a tech and over the last 6-8 months, the A/C takes forever to get cold.
I took it in for service and they found it was low on freon and there was leak in the manifold line. They also said the fan clutch was very weak, although we never had engine cooling problems since living in Arizona. We had the manifold lines and fan clutch replaced, along with normal A/C service.
Everything was good for a few days and then we noticed the air wasn't as cold anymore and that it started taking longer to get cold again. We are about a month out from all that service and my wife calls today to say the engine is making strange noises and that only hot air is coming out of the vents. She said temp gauge was normal, but there was a burnt smell.
The mechanic says the compressor is now locked up and the entire A/C system needs an overhaul to the tune of $1200. Is this reasonable and realistic, or is there a less expensive solution?
Thanks in advance for any replies.
