Are you saying that the condition is: Temporary? Say air temps at 80 degrees F......you're at 40 degrees F when you're cruZing around town........but, about 50 degrees F when on the highway at highway speeds. Then, returns to 40 degrees F when you hit town again. Some, system temp fluctuations are normal.
It has been said before:
Check the air temp and compare it w/ the vent temp. At an air temp of 75-80 degrees F, you're looking for a 35-45 degrees F at the vent (about a 40 degree F difference, though close enough is good to).
Though, IF it's ONLY at hghway speeds...........I'd say take it back and complain. Give the shop the first chance to make it right.
IF you aren't comfortable with the shop having a chance at it. You could re-check system pressures and check (when it occurs) IF the lines aren't freezing (causing a temporary restriction).
BTW....you said in another thread:
Update: I removed the orfice tube and it was in the line like it got sucked out of its seat and was bent same as the pipe. I am getting the right one from ford = red with 2 o-rings.
So, I assume you got all of the old tube out and changed the orifice tube, to the factory recommended one? And, what about the pipe? You said, "bent same as the pipe."
Aloha, Mark
PS....Note what color orifice tube the site below says should be used for a '96 Explorer........you once said......
also the original orfice was brown with two o-rings and the new one was white with 1 o-ring. i appreciate any help.
http://autoacrepairs.com/ford_orifice_tube_application9202.htm
I checked the NAPA web site and they also said: Red. You should/could also double check with the FORD dealership, about what color orifice tube to use. Maybe you "thought" it was brown due to contamination/discoloration and age. Ford Red, hole size .062......vs.......Ford Brown, hole size .047
