Aussie_jase
- January 1, 2003
- Newcastle , Australia
- 97 XLT SOHC 4.0L
Ok,
Just wanted to know if it is normal for the explorer to clunk a little when moving off in 4x4 low range. It does it when on the sand , its like as if it takes a second or two for the hubs to lock or something , anyone know?? Also, does the GEM module have a history of causing problems changing from low range to high range and vise versa?? Mine has an intermittent problem of changing ranges , sometimes it will do it , sometimes it wont?? No lights flash when it happens , just the 4x4 low light stays on as if it doesnt know to change? Any reason why it may not want to change? Could it be a heat problem because it only does it when the car is failry hot, like i can feel the heat on the transmission housing. Any help would be great.
